Cruise Control - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2008, 05:37 PM   #1 (permalink)
Gen 2 Camry
WannaBButch's Avatar
View WannaBButch's Photo Gallery
2nd Generation Cruise Control
I have a 1990 Camry V4 and the cruise control isn't working. The switch doesn't even light up. I swapped out the switch once and the switch its self is getting power. Any clues?
WannaBButch is offline   Reply With Quote
Old 03-22-2008, 12:37 AM   #2 (permalink)
View aych's Photo Gallery
i think the cruise control is powered by some kind of pump.. water I believe. Mine's crapping out and its really loud, and the speed ranges within like 10 km. i think if that goes your cruise wont work
aych is offline   Reply With Quote
Old 03-22-2008, 09:00 AM   #3 (permalink)
Gen 2 Camry
2nd Generation
That's not the problem. The water pump has nothing to do with it. The cruise only worked one time when I bought the car about four years ago.
Old 03-25-2008, 05:08 PM   #4 (permalink)
Gen 2 Camry
2nd Generation
Seriously? Of all the people here, no one knows anything about the cruise control?
Old 03-27-2008, 11:24 AM   #5 (permalink)
View jonsey1886's Photo Gallery
2nd Generation
Its a vacuum pump I believe, controlled by an actuator...I'm trying to retrofit my 1991 Camry with OEM cruise control as it came with all the wiring (as an optional accessory) and I bought it used w/o cruise.
Stuff to check: (smarter people feel free to add to this)
1.) Button on Dash (is it there, does it have power, etc)
2.) Control arm (thing on steering wheel) should be on right side with wiper/washer control and say cruise/ set/ accel/ etc, etc, (is it there, etc, etc, etc)
3.) Cruise control computer (located under the front passenger side kick panel just above fuse block)- this a pain in the *** to get to and involves taking off the entire right side of the dash (from the glove box on down) to have enough room and view access the bugger. when you finally get that off you need to reach up above the fuse block and see if there is a nice little green/teal box...thats the computer. (again, is it there, does it have power, etc, etc, etc)
4.) Vacuum pump and control actuator (things that actually control cruise, maintains speed, etc)-inside your engine should be near the "top left" by your alternator I believe. see http://www.camrystuff.com/index.php?page=Gen2_Manuals for more detailed info.
That is the only part of the system I haven't managed to scrounge from a junkyard yet
Again this is from my experience on an automatic trans (manual probably requires some sort of clutch pedal add-on and more)...if I have left anything out can the more experienced people please add it on?
jonsey1886 is offline   Reply With Quote
Old 03-27-2008, 03:09 PM   #6 (permalink)
Gen 2 Camry
2nd Generation
Sorry I guess I should have specified. It is an automatic. Thanks a lot, that at least tells me where to start.
