Crank Balancer bolt stripped - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2008, 08:41 PM   #1 (permalink)
View leatherneck270's Photo Gallery
Unhappy Crank Balancer bolt stripped
Ok,, I took one week and dismantled my 3sfe, in frame. that will be the last time I do an inframe on that engine, the front of the engine no room to work. Anyway my question is this, the balancer bolt, Crank, is stripped, not by me but by someone prior. I rebuilt the top end and all is great, but now the front seal is leaking. the flats of the bolt are rounded and I don't have a clue. Easy out's to me would seem to weak for a bolt with that much torque on it. Any help anyone? again remember the engine is still in frame
leatherneck270 is offline   Reply With Quote
Old 03-26-2008, 08:46 PM   #2 (permalink)
View Skiermang's Photo Gallery
Most of the techniques I use won't work on the bolt due to the torque on it. I would search for someone with a welder that can get a nut welded onto the rounded bolt and you can zip it off with a big angry impact gun.
View my motorcycle trip writeups at motoblag.com.
Skiermang is offline   Reply With Quote
Old 03-27-2008, 08:30 AM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Unless the bolt head is completely rounded off try to find torque plus 3/4 inch socket and use impact gun.
On 84 Cressida the bolt head broke off due to the excessive torque, but the broken bolt portion was easy to retrieve as the torque builds up between th buttom of the bolt head and the pulley, not between the bolt and crankshaft threads (unless the bolt is crossthreaded or loctite is used).
Doctor J is offline   Reply With Quote
Old 03-27-2008, 09:57 AM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
if nothing else, grind the head completely off and back the shaft out, or use a big drill bit and drill it off
