Originally Posted by ThomasToTots
My next question is Does anybody have a map of where the fuel lines run? I have the FSM. but it just says to reconect the various pipes (it names them but doesnt say where they go) also I must be imagining things but the electrical pack (that long insulated pack of wires that runs next to fuel pipe and conects to the injectors) it has 3 plugs 1 black (pretty sure thats to cold start) and 2 white connecters (fuel inector connecters) I should have 2 more on there somewhere.
There are only three fuel lines: the supply line that goes to the fuel filter, the high pressure return line that goes to a metal hose near the charcoal canister and a small line going from the fuel rail to the cold start injector.
This is a picture of my new motor that
does not have the fittings for a cold-start injector:
I am afraid I don't have any good pictures of the wiring harness and how it connects to the injectors, but yes, you should have four injector connections along with the cold start injector plug.
The following pictures may or may not help:
