OBD-I Code #71 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2008, 04:33 PM   #1 (permalink)
Yota8791's Avatar
View Yota8791's Photo Gallery
OBD-I Code #71
Hi...As discussed in an earlier thread, the check engine light came on in my 1990 Camry LE (V6).
After running a test on the OBD-I, the Toyota morse code indicates: 71
I was wondering if anyone knows what code 71 means.
~*Happy driving!
Yota8791 is offline   Reply With Quote
Old 03-29-2008, 06:09 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
This code is for EGR system problem.
On V-6 engine:
the carbon plugs up the hole in the intake plenum where EGR valve is attached (remove and clean);
Inspect the vaccuum modulator, blow into the port on the bottom of it: if air passes-replace ;
inspect the ported vacuum switch (BVSV) if it is broken ,replace
Doctor J is offline   Reply With Quote
Old 03-30-2008, 10:24 AM   #3 (permalink)
Yota8791's Avatar
Dr J, very much appreciated.
I'll take a look at everything.
Old 03-30-2008, 10:35 AM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Inspect the hoses going from the EGR to the modulator valve as well. The one on the bottom often gets clogged up with carbon.
If the EGR valve itself is clogged up with carbon you may be able to chip it away with a small screw driver. Just be careful not to damage the diaphragm. Also, look down the tube that the EGR is mounted to. It doesn't need to be spotless but it does need to be able to pass exhaust gasses.
Kep
Old 03-30-2008, 11:48 PM   #5 (permalink)
Yota8791's Avatar
Kep, thanks for the tips as well.
I will be sure to inspect.
Hope everyone had a good weekend...
