'91 V6 Idle/stall when shifting to drive
My '91 v6 is having a stalling/idle problem. It runs good when driving except when slowing down and stopped. It idles good in park and when in reverse with brakes on or rolling back.
When it started doing this, I replace a leading front valve cover gasket due to oil in the plut tubes, put in new plugs, but no impact. I check on the forums and then cleaned the throttle body really good which helped the idle when parked and in reverse, but now it still dies when coming to a stop in drive or just sitting there with the brakes on in drive. I looked over the vacumn hoses - found one small crack and fixed it - no help.
Before changing the cover gasket and plugs, I thought my wife had gotten some bad gas and treated for that too. I put in high octane (93 exxon) and some STP treatment - but no difference yet. Also, several weeks ago I replaced the MAF and after that it ran like a top for several weeks. Then this just started. I've checked the connections to everything but haven't found anything loose (yet).
I just find it strange that it idles in park fine AND in reverse with brakes on but dies in drive unless I give it gas. Also, when I start to go in drive, it is very sluggish until building up some speed (20mph) and then seems OK. It starts up immediately after stalling off.
Has anyone heard of this situation? I don't have a computer code tool and hate to take it to a dealer just to put on the diagnostic or, worse, have them do a costly but simple repair that I could have done.
Ben
'91 DX v6 Camry Funster
'93 Mercury "Aussie" Capri
'94 Ford 4x4 "Exploder"
'?? Two-seat airplane wannabe
