Need help with ignition/timing troubles
Here is what i have: '88 3S-FE 5 speed. Today I went to do the AFM "cog" leaning trick, that is on the board. After reading the thread someone recommended turning the timing from 10* to 17*. When I bought the car it was up higher than stock. But I turned it back down when I gave it a tune-up. About 18,000 miles ago I changed plugs (NGK), new wires, cap, and rotor. The car ran great.
Now when I went to set the timing with my timing light the mark on the pulley keeps walking around the crank counter clock-wise. I did buy a new timing light I thought mine was bad, but it does the same thing right out of the box. So I know it isn't the light. Some thing is wrong with my car, and it is stumbling again around 2500 rpm no load. I had to set the timing this afternoon by driving down the road and turning it up until I hears knock and then turning it back a little. So I have no idea how many degrees I'm at.
So my questions are: Why is the timing mark walking around the crank? How does the car run light this? What is the cause, bad distributor, timing belt?
Why is the car suddenly missing? Am I due for a tune-up again? New plugs at least?
Thanks,
Dave
