Not sure if this is your first toyota or not, but getting genuine Toyota parts from the dealer is VERY worth it. To give you an idea, factory plug wires from Toyota will last upwards of 180K miles, plug wires from Kragen will last you 50K if you're lucky. Same goes with starters, alternators, water pumps, etc. The part from toyota will cost you twice as much, but will last 4 times as long.
Also, always run either NGK or Denso plugs, NEVER EVER EVER use Bosch, especially their multi-electrode plugs! Don't let the parts counter guys ever upsell you on this, and if you take your car to a mechanic, make sure they don't get upsold either.
At 180k miles, I would strongly suggest replacing the shocks; good shocks increase handling, acceleration, and decrease stopping distance. I suggest Monroe Sensatracs for 90% of drivers.
Hope that helps!
