Yup, once I started messing around with the door it just rattles all the time now. There's two screws near the door hinge, one underneath the arm rest, one on the handle itself (pry off the cover), and the obvious one in the center of the door latch. Once those are out, the panel is held on by clips so you might want to use the special tool for those or something. When I recklessly pulled mines, I snapped a bunch of them. I just used the thick foam tape to put behind those bars behind the panel itself and it helped some.
