What are the oxygen sensor voltages for rich/lean?
I don't have a air/fuel ratio gauge. I was wondering if I could connect my digital multi-meter to the oxygen sensor wires and read the voltage that is coming off of it. I'm experimenting with the AFM mod, setting the tension of the spring, the "click" mod. I would like to know were I'm at right now with the air/fuel ratio. Can someone list the different voltages for rich to lean, and if you know the voltage to ratio, example: 3 volts = 14.7 A/F, something like that.
Thanks.
