91 wont start after new plugs and fuel filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2008, 11:38 AM   #1 (permalink)
View systemrobot's Photo Gallery
It was running poorly, missing a bit, so did the plug wires and cap and rotor, still ran poor, changed the plugs and fuel filter, won't start, replaced the fuel pressure regulator, won't start.....now what, thanks in advance...
systemrobot is offline   Reply With Quote
Old 04-20-2008, 12:38 PM   #2 (permalink)
noticed a crack along the coil so will replace and see
Old 04-20-2008, 02:24 PM   #3 (permalink)
new coil in...still no spark....now what....
Old 04-20-2008, 03:26 PM   #4 (permalink)
tried to check diagnostic codes but i get nothing from the CEL not even when the key is on...just stays off.......please help.....
Old 04-20-2008, 06:23 PM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Check all connectors on the distributor, look for bent terminals
Doctor J is offline   Reply With Quote
Old 04-20-2008, 10:25 PM   #6 (permalink)
Gen 2 Camry
WannaBButch's Avatar
View WannaBButch's Photo Gallery
2nd Generation
Not to make you sound ignorant but did you install the fuel filter correctly? The lip should be at the bottom. I had to double check when I changed mine and I almost did it backwards. It just seems that the lip should be at the top.
WannaBButch is offline   Reply With Quote
Old 04-21-2008, 09:50 PM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Since the CEL doesn't come on at the POST the EFI Main Relay may be bad. Also check the EFI fuse. It may be something else but these are easy to check.
Kep
