Emergency Brake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2008, 02:16 PM   #1 (permalink)
Gen 2 Camry
WannaBButch's Avatar
View WannaBButch's Photo Gallery
2nd Generation Emergency Brake
How do you remove the rubber handle on the ebrake?
WannaBButch is offline   Reply With Quote
Old 04-23-2008, 10:57 PM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
I'm pretty sure it's actually formed right onto the metal lever of the handbrake. Kinda like they melted the rubbery plastic right on there. I've never seen one come apart.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 04-24-2008, 10:01 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If you want to go to the trouble go get one at a junk yard and try a few things. I would try dipping the end with the rubber sleeve into hot water and see if it would expand enough to slip off (kind of like a bicycle handle bar grip). If something works then you can work on yours. If not, you only loose the junk one. The last thing you might try is to cut the junk one open lengthwise and see if you can discover a trick.
Kep
