Brian,
Can't stress enough the importance of picking up that manual, especially if you have not done a lot of work on these cars. It will give you step by step. you can find them on E-bay on a regular basis. There are several torque specs that are listed , most will be hopefully done when you go back to take it for an alignment.
these are for my 1986 Camry, guessing there the same for 85.
Front strut:
top shock absorber to body 3 nuts 27 ft-lb
bottom shock to steering knuckle 2 nuts 152 ft-lb (should be done when re-aligned)
Rear strut:
top of shock absorber to body 3 nuts 17 ft-lb
bottom shock absorber to axle carrier 2 nuts 119 ft-lb (should be done when re-aligned)
Again I would recommend getting the book then rechecking the other torque's (caliper's , etc.) when you get it.
Bill
1986 Camry DX 363,000 miles
1986 Camry LE hatchback
1978 Ford Australian XC Falcon Cobra
1958 Plymouth "Christine" Original car used in filming
1971 Detomaso Pantera (in restoration)
