'85 fuel problems
'85 Camry DX auto w/ 101k miles
Just recently after running the car down to the low fuel light and then filling up at a Chevron, the car is suddenly having some major issues. It's acting like it's running out of gas.
It started with just a little cutting out when trying to merge on the freeway, and has since gotten worse. I was able to free rev the car while in park but the car had a lot of trouble climbing rpms when in drive (under load). Now it won't rev in park or drive easily. Hitting the gas just makes the car cut out and stumble. The car always had a bit of a drop in power mid rpms. Felt like it would would kinda hit a dead spot.
When I start the car cold, it almost acts normal. As soon as it starts getting warmed up, it starts stumbling and cutting out bad. Car idles fine most of the time. On light throttle the car will move but won't really go past 25mph. If you try to mash the gas the car just stumbles and slows down.
I just recently (about 1,000mi or so before the problem) replaced the fuel filter and plugs.
Could it be a dieing fuel pump? (well pretty much dead now because the car has gotten even worse)
Is there a way to check the fuel pump to see if it's working properly? Do I need to drop the tank to do the fuel pump?
1992 TOYOTA MR2 - 180k miles * 2003 TOYOTA MR2 Spyder - 87k miles * 2006 SUZUKI SV650s
2002 TOYOTA Highlander 4wd Limited V6 - 25k miles * 1985 TOYOTA CAMRY DX - 130k miles * 1987 HONDA Elite 250
Hers ~ 1988 TOYOTA MR2 Supercharged - 87k miles * 1999 TOYOTA TACOMA - 125k miles
