ok thanks!
So i found my old Haynes manual from my CELICA and was reading some info on checking the coil and TPS and they list the 3s-fe motor, which is what i have (think).
I checked the primary resistance on the coil with 2 different digital multimeter's and found the following:
- one read 1.0 ohms and the other 0.8 ohms
According to the celica book, the 3s-fe should be from 0.4 to 0.5ohms
Secondary resistance was 9.5k ohms and 9.8k ohms; celica book has a typo and lists the 3s-fe motor twice one being 10.2-13.8 k ohms and the other 7.7-10.4k ohms. So i'm thinking the ladder is the correct numbers for comparison.
TPS:
This is where the book had conflicting illustrations. It shows a pic of the 3s-fe tps with 3 pins....well mine has 4 pins similar to the 3s-ge in the book. So i check for connectivity between 3rd and 4th pin, with the throttle butterfly at .02 inch , with nothing. I opened it up all the way and still no connectivity
So what i've found is the primary resistance is double of the celica book and the tps isn't indicating any connectivity.
Can anyone please confirm these numbers if possible, or provide some feedback if i'm on the right track?
Does it look like the ingnition coil is toast? or the tps?
Also this car does have command start installed. I know some places use the tps to read that the car is started. I'm hoping it has nothing to do with that.
Sorry for the long post, but i really need to get this car working 100% for my mother.
DR any advice?????
