That line is essentially a drain fitting. If you look on the top surface of the crossmember that runs under there (from left to right) then you'll see a rubber grommet where it is supposed to insert. There's a small space inside the crossmember there where the drain (or vent, or whatever the heck it is) goes, and the gromet is supposed to hold it in place. Nothing to worry about, just zip-tie the line out of the way if it won't fit back in the grommet...
Tim
 1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
