Window problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2008, 01:10 PM   #1 (permalink)
View Lee250's Photo Gallery
Gen1 Window problems
My windows don't work like they should. You have to push down on the back of them while rolling them down, rolling them up is fine. I know it's the slides or rollers or something but where could I get those kind of parts?
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 05-06-2008, 01:07 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Pull the door panel off and check the regulator connections and the connection from the window to the regulator. There are a half dozen bolts and if some are loose the window might act like you are describing. While you're in there, lubricate all of the joints and the gear.
Kep
Old 05-06-2008, 04:40 PM   #3 (permalink)
View Kingdom934's Photo Gallery
Kep
Yep.
Also might have to see if the rubber lip where the window goes down that could be causing it to get stuck? (if it is seeming to get stuck).
I've use white grease. Not sure if thats good but it seemed to work a bit.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
