Any chance that this just happened after you replaced the two filament bulb?
Not sure about an 87 model. If the lenses are in the trunk lid the most likely location is where the wires go along the hinge at the trunk body. These flex each time you open the trunk and will damage wires over time.
Make sure to check your ground connections as well. Poor or loose ground connections can cause wierd problems.
Kep
