1990 Camry Wagon DX Oil??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2008, 09:16 PM   #1 (permalink)
Gameroom cash: $202300
View zppeacock's Photo Gallery
Im picking up a 1990 Camry Wagon on Wed hopefully. Its got 231,000 and I just test drove it today and it runs perfect. There is no owners manual in it and I was wondering how many quarts of oil it holds? And any other things I should replace/clean after I pick it up. Its starting to rust (Wisconsin winters) but for $800 I couldn't really not buy it.
zppeacock is offline   Reply With Quote
Old 05-10-2008, 09:35 PM   #2 (permalink)
91CamryMan's Avatar
View 91CamryMan's Photo Gallery
My v6 holds around 4.5 quarts not sure about the 4 cyl.
____________________________________________
91CamryMan is offline   Reply With Quote
Old 05-10-2008, 10:29 PM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
I4 has about 4quarts but spec is 4.3 but i always used 4 w/o any problems
Old 05-10-2008, 10:36 PM   #4 (permalink)
Thanks any other things that I should replace?
Old 05-11-2008, 01:50 AM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
oil filter... check timing belt & other belts... radiator hoses?? ... new coolant? you have to ask for the history of the car
Old 05-11-2008, 11:11 AM   #6 (permalink)
Ok, thanks
Can anyone link me to the correct transmission filter kit?
Old 05-11-2008, 03:44 PM   #7 (permalink)
View Cutshaw's Photo Gallery
Check the spark plugs condition, you can tell a lot. Also consider replacing wires/cap/rotor if they look old.
http://www.tuner-junction.com/TJForu...ark-plugs.html
Cutshaw is offline   Reply With Quote
Old 05-11-2008, 05:17 PM   #8 (permalink)
Any Recommendations on a plug brand?
Old 05-11-2008, 08:37 PM   #9 (permalink)
Pochacco Owns Me
atobe's Avatar
ngk or denso
Old 05-14-2008, 01:26 PM   #10 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
Im running Bosch platinums in my 87 Sedan no problems so far with them .
disregard is offline   Reply With Quote
Old 05-14-2008, 01:33 PM   #11 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Other than NGK and Denso, the Bosch Platinum are the only other plug that I've had luck with. Avoid Champion at all costs...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 05-14-2008, 09:43 PM   #12 (permalink)
Got it today, while I was testing all the power windows the drivers rear went down and didn't come up. So I had to pull the panel and loosen the motor to get it in the up position and then unhook the power to the motor.
While I was driving it home 10 miles about half way the check engine lite went on, I didn't feel anything wrong and when I turned it off and then back on the lite went off.
I picked up alto of parts today that are going to get put on hopefully tomorrow.
Old 05-14-2008, 11:52 PM   #13 (permalink)
Bullitprooph
Run a diagnosis on the check engine light, and fix it before it gets worse and/or causes other problems...probably an O2 sensor fault.
Old 05-15-2008, 07:10 AM   #14 (permalink)
How do I do that? I saw the diagnosis box under the hood
Old 05-15-2008, 06:47 PM   #15 (permalink)
Well today I changed the oil, oil filter, plugs, air filter, and tranny fluid/filter.
Seems to be running great for a 231,000 mile motor.
