Fuel Mileage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2008, 08:05 PM   #1 (permalink)
View aych's Photo Gallery
Fuel Mileage
Hello Everyone, just wanted to share Fuel Efficiency with everyone. Wondering what people are getting.
Currently I'm sitting at 7.4/100km or 30.1 mpg. Thats alot better than my old 10 / 100km or 24mpg.
You think I can do better?
aych is offline   Reply With Quote
Old 05-15-2008, 02:55 AM   #2 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
View TVISMR2's Photo Gallery
Mixed driving with mostly highway I get 34mpg. Sometimes with the AC on as well. I'm expecting more now though with the new fuel pump. Car had some power issues before the pump change. I had a slowly dying pump.
Worst I ever got with the car was 28mpg... but that was with the roof rack bars on with freeway driving. I don't have a fairing for the front bar though so the wind drag is pretty bad.
1992 TOYOTA MR2 - 180k miles * 2003 TOYOTA MR2 Spyder - 87k miles * 2006 SUZUKI SV650s
2002 TOYOTA Highlander 4wd Limited V6 - 25k miles * 1985 TOYOTA CAMRY DX - 130k miles *
1987 HONDA Elite 250
Hers ~ 1988 TOYOTA MR2 Supercharged - 87k miles * 1999 TOYOTA TACOMA - 125k miles
TVISMR2 is offline   Reply With Quote
Old 05-15-2008, 07:37 AM   #3 (permalink)
87 Wagon's Avatar
View 87 Wagon's Photo Gallery
What should wagons be getting, I have an 87, Auto, LE and so far I have had the car for about a month or more and first tank full was 24 and this past tank was 26mpg. Would like to get better but thinking the wagon may be a bit worse than the normal 4 or 2 door.
Any other wagons out there with input??
Thanks
Bernie
Bernie
MECP Certified
1987 Camry Wagon - http://www.cardomain.com/ride/3139320
Raw Custumz --http://community.webshots.com/user/RawCustumz
87 Wagon is offline   Reply With Quote
Old 05-15-2008, 07:42 AM   #4 (permalink)
jmj99f's Avatar
View jmj99f's Photo Gallery
After cleaning, throttle body and adjusting timing I'm getting 31 MPG. Next, I need to replace my fuel filter.
Peace
jmj99f is offline   Reply With Quote
Old 05-15-2008, 10:12 AM   #5 (permalink)
whoa! so my 30 doesn't seem so good afterall. I am actually more used to 24. Maybe its because I'm on higher elevation? Hows the work in replacing the fuel filter, do I need to drain anything?
Old 05-15-2008, 12:59 PM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Yeah, I got you beat...
On my old '90DX 4-cylinder 5-speed I would average 28-32mpg in city driving. On freeway trips, I would average 36-38mpg. I actually got almost 500 miles on a tank one time...
On my 'newer' Camry when it had the stock motor turbocharged, I would still get high 20's in mixed driving (and I got over 30 on a few tanks). Now with the 3s-gte I get in the 20-25mpg range in mixed aggressive driving (with a leaking gas tank!).
My Alltrac auto gets 22-26mpg, but on my latest trip to Sacramento and back I had a tank at 28mpg.
Pretty much, I've been able to match and beat the old-style EPA mileage ratings in every car I've owned (even my WRX). Be easy on the throttle position changes (no sudden movements of the foot), be reasonable on the freeway (I go 72mph, generally which is slow in LA) and keep the car tuned up...
-Charlie
Old 05-15-2008, 02:27 PM   #7 (permalink)
I'm actually having to employ all sorts of hypermilling techniques to get the 30mpg. i rarely go above 2500rpm's too
Old 05-15-2008, 05:16 PM   #8 (permalink)
Gameroom cash: $150200
View 66conv6's Photo Gallery
2nd Generation
88 Camry LE. Driving from Kingman, Az to Los Angeles late at night at 98mph I'd get 22mpg for 3hrs 45mins and can go roughly 275 miles before running out of gas. If I slow down I can just make it on a tank of gas. A fill-up is about 15.5 gal. If I slow to 80mph I get about 30mph. If I slow to 60-65mph (late at night 2.5 hour drive) I can get 38-40mpg. FYI if you lose 200lbs of weight it makes a difference of about 1mpg if I recall correctly. I pump up my tires to their max psi of about 45. I use Mobile 1 synthetic. I turn off A/C and all electricals when climbing steep grades.
66conv6 is offline   Reply With Quote
Old 05-15-2008, 05:35 PM   #9 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
I had my 87 camry sedan for less then a month now. What are some things I can do to improve fuel mileage besides tune up (plugs wires cap rotor) ?
Im assuming with the highmileage theres all sorts of deposits of dirt and carbon lying around everywhere. what can i do to clean all this crap up ?
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
Old 05-15-2008, 11:24 PM   #10 (permalink)
hm. interesting. if I run city mix of 60km/h and 80km/h no AC and just stock radio I'm still averaging 22-26mpg. apparently my fuel filter has been replaced about 14 years ago and my tires are at stock 30psi. quaker oil green bottle for me
Old 05-16-2008, 12:38 PM   #11 (permalink)
white90dx's Avatar
Where do you get your info on hypermiling? I already just naturally do most of those techniques while driving anyway (especially the 'smoothing' of traffic).
-Charlie
Old 05-16-2008, 09:09 PM   #12 (permalink)
Blazyntoyo
View 90camdx4's Photo Gallery
90 dx with jdm 3sfe,auto...32 mpg 90% highway driving, speeds between 110-120 km/h,
90camdx4 is offline   Reply With Quote
Old 05-21-2008, 10:13 PM   #13 (permalink)
View Dave88LX's Photo Gallery
My wife gets 37-38mpg, I get about 33.
Dave88LX is offline   Reply With Quote
Old 05-22-2008, 01:00 AM   #14 (permalink)
hm. now thats more normal!
Old 05-22-2008, 02:47 AM   #15 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
I've been running "yard gas" (the stuff we drain out of vehicles as they come in to the wrecker's where I work) exclusively for about seven months now. When I started running it, the 3SFE was getting about 30-32mpg in town. Now, it's down to about 25mpg. The filter on our storage tank must be getting clogged, and now so is my Camry's fuel filter, I imagine...
P.S.: Oh, by the way, the yard gas is free--otherwise I'd reconsider running it. I've saved about $2000 since November, so a fuel filter every few months concerns me not at all...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
