1985 valve tick problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2008, 09:58 AM   #1 (permalink)
View itwonder's Photo Gallery
I just got a 1985 with 140K. It has sat for 3 years, and was driven short trips only prior. Has loud valve tick that comes and goes, seems to happen mostly when engine is about 1/2 way warmed up. I doubt valves have ever been adjusted, and I will do that. But since this is not a constant tick, but comes and goes, I think it is something else. Ideas?
itwonder is offline   Reply With Quote
Old 05-16-2008, 10:31 AM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
2se?
Old 05-17-2008, 07:08 PM   #3 (permalink)
View Kingdom934's Photo Gallery
I would assume it is the 2SE. You got an audio clip of the sound? Hows the oil in that car?
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 05-17-2008, 10:30 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
probably piston slap
Old 05-18-2008, 09:59 PM   #5 (permalink)
I will try to make an audio clip of it. It is a 2SE. I doubt the noise is piston slap.
Old 05-19-2008, 01:42 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I am suspicious that it might be a sludge problem that doesn't allow enough oil to get to the valves. Have you pulled the valve cover to inspect the insides? Sea Foam in the oil might help...
Kep
Old 05-20-2008, 11:22 AM   #7 (permalink)
Banned
View DressUpYourPet's Photo Gallery
I am thinking the problem perhaps is : One or more sticky valves? The car sat for several years after all. Try an additive like seafoam or marvel mystery oil and a couple oil changes in a row.
If this doesnt do the trick, it might not even hurt to remove the valve cover and soak the valves around the valve guides with seafoam, and let it sit overnight. Then run the engine for a few minutes, then do an oil change. This might free up a sticking valve, if thats what the noise is.
DressUpYourPet is offline   Reply With Quote
Old 05-23-2008, 12:25 AM   #8 (permalink)
Gosh, I hate to see how my top end looks. All I saw from the small hole when replacing the PCV valve was a nightmare (a lot of black specks). Blame that from my uncle.
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 05-23-2008, 09:47 AM   #9 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
i highly doubt you will find a chevy rocker arm under the valve cover but if it is a stuck valve the shim might have came out from under the cam that sits on top of the bucket that covers the spring, thing to do is on each valve turn the cam so the lobe is pointing up and take a wood hammer handle and put it on the bucket and push down a little and see if it moves easily, just watch out for the shim
Old 05-23-2008, 04:34 PM   #10 (permalink)
Banned
yeah you are right fred i changed the picture
Old 05-23-2008, 10:53 PM   #11 (permalink)
I've changed the oil with Shell Rotella 5W-40 synthetic, plus 6 oz. of Seafoam. The Rotella is formulated for commercial vehicles and it has a better detergent package than most other oils. I had good luck with it helping a Nissan VG30 engine that had a similar problem. It is API SL rated. We'll see what it does for the Toyota.
The 2SE is single cam, with rocker arms and "lash adjuster" according to a diagram I found at autozone.com. I snagged a 1985 repair manual from ebay, and as soon as it arrives I'll pull the valve cover to investigate further.
Old 05-24-2008, 02:34 PM   #12 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
Ive never ha a 2se apaRT, from the pic it has hydraulic lifters under one end of the rocker and the valve under the other?
Old 05-27-2008, 11:23 AM   #13 (permalink)
View marc780's Photo Gallery
Since it has rocker arms opening the valves, this means the valve clearance is probably adjustable. So why not pull the valve cover and check the clearance, if you know how? The engine needs to be hot or warm before you do this.
Also i'd squirt some seafoam around the valves as long as the valve cover was off. It might help loosen any crud in the valve guides.
