4 cyl to 6 cyl engine swap. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2008, 06:42 PM   #1 (permalink)
View automattick's Photo Gallery
Hi. I have an 87 camry 4 cyl/auto. I have an opportunity to get a rolled 91 6 Cyl/auto for free. Would the 6 cyl tranny hook up to my 4 cyl engine? Would it be easy to install the 6 cyl/tranny combo in the 87? Would the computer/harness stuff match? I'm trying to decide if I want this free car. Thanks!
automattick is offline   Reply With Quote
Old 05-19-2008, 07:29 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
the tranny will bolt on.. but you'll need new axles.. since they're different for the I4 and V6... engine won't bolt on.. different motor mounts... also harness won't work... also you'll have to use the V6 ECU. and make a hybrid harness for it... not worth the trouble if u ask me
Old 05-19-2008, 11:42 PM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Don't do it. Too much chop-and-mod to make it a reasonable swap.
Take the free car and part it out, assuming you have the space to store it and the patience to deal with the public.
Or, take the free car and scrap it. I don't know about your region but the scrap company I work for is paying $250/ton right now for scrap vehicles. A V6 Camry would net you about $375...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 05-20-2008, 03:10 AM   #4 (permalink)
View aych's Photo Gallery
if ur gona swap do the 3sgte
aych is offline   Reply With Quote
Old 05-20-2008, 11:14 AM   #5 (permalink)
Banned
View DressUpYourPet's Photo Gallery
i concur...its not particularly easy swapping in a new engine of the exact same kind as the old one. Add in a non-factory engine to the mix and you're asking for an expensive, troublesome hassle that may not even work right.
Swap in another engine of the same kind or rebuild the old one if its worn out. If it isnt, leave it alone.
DressUpYourPet is offline   Reply With Quote
Old 05-20-2008, 03:45 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
your gonna need the entire powertrain, trans, axles, hubs struts and radiator and pretty much everything ahead of the firewall, but if it ran good and isnt torn up, go for it
Old 05-20-2008, 06:51 PM   #7 (permalink)
Thanks for all the replies! I hate to pass on something free. I might go take a closer look and think about scraping it.
Old 05-21-2008, 02:40 PM   #8 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
I would either scrap and hope to get atleast 300 for the scrap. or take it apart and sell the engine/trans. Hell you could even put up listings on ebay and sell the parts one by one, that way you would make more money in the long run.
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
Old 05-21-2008, 02:45 PM   #9 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
View TVISMR2's Photo Gallery
Or a later model 3sge, or a 1mzfe, or even a 5sfe.
1992 TOYOTA MR2 - 180k miles * 2003 TOYOTA MR2 Spyder - 87k miles * 2006 SUZUKI SV650s
2002 TOYOTA Highlander 4wd Limited V6 - 25k miles * 1985 TOYOTA CAMRY DX - 130k miles *
1987 HONDA Elite 250
Hers ~ 1988 TOYOTA MR2 Supercharged - 87k miles * 1999 TOYOTA TACOMA - 125k miles
TVISMR2 is offline   Reply With Quote
Old 05-21-2008, 03:59 PM   #10 (permalink)
disregard's Avatar
Yeah a 5sfe swap is in the plans if my old 3sfe ever breaks down.
Old 05-22-2008, 02:54 AM   #11 (permalink)
Bullitprooph
Man, from the work I've done on the 1MZ, you'd be better-off dropping a big block into a 1968 Mini Minor. If you think the 2VZ (2.5L)is hard to mod onto 3SFE mounts, the 1MZ--at 3L--is a Rubik's Cube. Bad, bad, bad idea...
Old 05-22-2008, 07:06 PM   #12 (permalink)
disregard's Avatar
Yeah your better off just going with a bigger 4cylinder or a high performance 4 cylinder.
atleast then you have room to move around when something goes wrong and you need to install new parts.
Me personally I would like to see the newer 2.4 vvti (160 HP) in one of our 2nd gen camrys. If I could burn rubber in it while in a 3300 LB 2002 camry LE
4 speed automatic. Imagine what it could do in our cars thats atleast 500 pounds lighter ?! It could easily match or beat the 2.5 v6 and get much better gas mileage than it can because it has variable valve timing in a much lighter car.
Old 05-22-2008, 09:06 PM   #13 (permalink)
Bullitprooph
That's actually a very intriguing option that I had never even thought of...
Old 05-23-2008, 12:47 PM   #14 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
The 2vz-fe, 3vz-fe and the 1 or 3mz-fe are all about the same size, externally and should all be about equally difficult to get in the gen2 Camry... You only have to do one custom mount on the MZ motors.
As for the 3s-gte, it is significantly more difficult to work on than the 3s-fe. Check out all the room in my engine bay:
-Charlie
Old 05-24-2008, 01:48 AM   #15 (permalink)
Bullitprooph
Man, pics like that always put a big sh!t-eating grin on my face. You may complain about the lack of space under the hood, but I know you know it's TOTALLY worth it...
