It takes a 30mm socket and torque it down to only 17 ft lb. Before you remove the tube gaskets make a note of how they are positioned and which tube that they are on. Reinstall them the way you found them It would be best if you also replace the gaskets under each nut, if you do again put them on in the same orientation as the ones you removed. The manual goes into more detail.
Kep
