140E Tranny Swap - Tranx fluid question... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2008, 08:47 PM   #1 (permalink)
View diverjeff's Photo Gallery
Hello all,
Just finished a tranny swap on my '87 Camry. Put a '91 A140E back in. Does the transaxle use the same fluid as the transmission? If I fill up the transmission and it reads full on the stick does that reading mean the transaxle is also full?
I question because there are two separaate drain plugs.
Appreciate any help.
Respectfully,
DJ
My wife said if I don't quit buying vehicles that need work she was going to leave me..... I'm sure gonna miss that woman.
diverjeff is offline   Reply With Quote
Old 05-29-2008, 04:50 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
My 90 camry 3SFE engine had a separate drain and fill for the differential. Is that the same as a transaxle? I believe that both fill and drain used a 10 mm allen wrench and it took about a 1/2 quart of the same transmission fluid that the auto transmission used. The main caution that I can give is to loosen the fill port first. That way you're certain that you are able to refill the differential before you drain it!
Kep
