No pics handy, but can you be more specific about which rubber part is torn? Do you mean the dust cover that hangs down around the strut cylinder (inside the coil spring)?
As for front-to-rear height, the rear always looks slightly lower than the front (measuring from the top of the tire to the edge of the wheel well). However, if the rear is really sagging then the gas charge in your rear struts has begun to leak out and you'll have to replace them soon.
 1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
