3S-FC spark plug well tension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2008, 03:12 AM   #1 (permalink)
View allocated's Photo Gallery
could someone tell me what the tension is for the spark plug well please
its a toyota camry 1989 model
allocated is offline   Reply With Quote
Old 06-10-2008, 09:52 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If, by tension, you mean torque, Gen 2 manual shows 13 ft-lb (180 kg-cm or 18 N-m) for the spark plugs themselves.
If you mean the 30 mm nuts on the tubes that hold the valve cover down their torque is only 17 ft-lb for the 3SFE.
Kep
Old 09-19-2008, 07:50 PM   #3 (permalink)
thanks for the reply, it fixed my toyota and still fine
Old 09-19-2008, 10:15 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
pull em down till the tops of the tubes come to the top of the nuts, and be prepared to do this a few more times if your motor has alot of miles on it
