Books have been written on how to buy used cars. That being said - the suspension (rubber parts), the axles (while driving slow, turn wheel all the way right and all the way left it should not click), the AC should work without clattering, verify each light and switch operate. Drive over a wet patch - you should only see two tracks, not four. Rust is a no no. Clean is better than dirty. and on and on and on...
Get the VIN before buying the car and run a carfax report on it. If you need to travel a long way to see the car, do this before making the trip. Ask for the maintenance history on the car. Especially, the transmission.
Luck,
Kep
