1990 Camry Wheel Hub Assembly - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2008, 12:53 PM   #1 (permalink)
View bri_guy636's Photo Gallery
How hard is it to replace this? After the shop gave me a 420 dollar estimate to replace the hub i'm thinking of doing it myself. Front drivers side btw.
The wheel will move up and down with alot of play, and tire makes a shuddering and thumping noise.
Do I need a torque wrench? The shop stated that they would need to remove the entire spindle unit to replace it.
Thanks in advance,
Brian
bri_guy636 is offline   Reply With Quote
Old 06-10-2008, 02:07 PM   #2 (permalink)
View toyomoho's Photo Gallery
Front or rear?
Old 06-10-2008, 02:09 PM   #3 (permalink)
Its the front driver side
Old 06-10-2008, 03:55 PM   #4 (permalink)
The hub needs to pressed out of the bearing, then bearing pressed out of the hub. You will need to remove the knuckle and need a press or a shop that has one. Axle nut need to be torqued.
AutoZone has a got site on this:
http://www.autozone.com/addVehicleId...00c15280074780
Old 06-10-2008, 06:59 PM   #5 (permalink)
Thanks for the quick reply, ive found a reliable person that will do it for 60 dollars labor if i supply the parts, and im just going to buy the whole hub and bearing together.
Thanks,
Brian
