So using a small flat screw-driver, I took off the black plastic frame surrounding the radio and the ashtray (including the little coin-money holder on the top left). I wrongly thought the bottom was attached by some screws because it didn't want to come out. But after a few minutes trying, it did.
After taking out the radio, I found a black box right behind the radio. It says Denso 077300-1481. I thought: Bingo, here's my ECU.
But when I check with a repair manual photo, the connector pin does not match. Which means this was not the ECU I was looking for. How sad ! The box I got has: white: 14 pins, blue: 18 pins. In the repair manual, there are many more pins than that.
Does anyone know where the ECU, please ?
Thanks for your replies.
