Master Window Switch Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2008, 05:09 PM   #1 (permalink)
View mcbradford's Photo Gallery
I have an 88 LE wagon w/ the 2.0L
The master window switch was sort-of working (slow). Then it stopped working (will not control any window) only the door lock works.
I took the door panel off, lubed up the tracks - applied 12v to the motor and the window goes up and down fine.
I just went to the salvage yard and picked up another switch. This one is doing the same thing. Do you think it is another bad switch? They said it comes with a 30 day warranty. Should I switch it out for another - or do you think something else is going on??????
mcbradford is offline   Reply With Quote
Old 06-13-2008, 06:45 PM   #2 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
it could be a fuse.
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
Old 06-13-2008, 08:13 PM   #3 (permalink)
View toyomoho's Photo Gallery
Check the wires running between the drivers door and chassis for breaks.
Old 06-13-2008, 10:56 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
^+1
What Toymoho said, Since so many functions are out it is likely one of the ground wires (I believe that there are two). If you are comfortable with a multimeter you can do a lot of testing at the master switch wire loom. Do a search for "master switch" an you will find a lot of posts on this.
Kep
Old 06-14-2008, 09:10 AM   #5 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Pull the switch out WITH connector ATTACHED;
turn ignition on
clip the test light to the good ground (NOT the DOOR)
probe the light blue thick wire in the center of connetor (power wire] if light is on you are getting power to the switch;
now using the jumper attach the connector terminal of the WHITE WIRE WITH BKLACK TRACER TO THE GOOD GROUND.
TRY THE SWITCH
If the window works now , repair the ground wire.
Doctor J is offline   Reply With Quote
Old 06-14-2008, 01:54 PM   #6 (permalink)
I was going down the road and decided to give the window a try - and guess what - now it is working. I agree, I think it might be a ground problem. I will go through the ground problem.
Old 06-14-2008, 04:16 PM   #7 (permalink)
Doctor J's Avatar
With engine running these extra 2 volts [14 v alternator vs 12 v battery] may be able to push necessary current through corroded terminals.
