Automatic Transmission Fluid instead of Power Steering Fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2008, 08:06 PM   #1 (permalink)
elahi's Avatar
View elahi's Photo Gallery
2nd Generation Automatic Transmission Fluid instead of Power Steering Fluid?
My Power Steering Fluid was finished. I have wrongly used Automatic Transmission Fluid instead of Power Steering Fluid. Will this be a problem? Do I need to change?
elahi is offline   Reply With Quote
Old 06-17-2008, 08:37 PM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
you'r suppose to put ATF in there
Old 06-17-2008, 08:43 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
^+1 ATF is the correct fluid for your power steering. Read the "label" on the reservoir cap.
Kep
Old 06-17-2008, 09:07 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
no, no
Old 06-17-2008, 11:22 PM   #5 (permalink)
elahi's Avatar
Thanks for your replies. But ATF and PSF looks like same. If the fuil does not match, do I need to change? Will there be any problem?
Regards,
My car: Camry 1989 V6 Auto
Old 06-18-2008, 11:37 AM   #6 (permalink)
Kep
Kep's Avatar
If you put ATF in your power steering system you put the correct fluid into it. Is that what you did?
Kep
Old 06-18-2008, 06:57 PM   #7 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
what kind of atf dextron II or III ?
Both of those would work right ?
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
Old 06-18-2008, 07:33 PM   #8 (permalink)
Pochacco Owns Me
atobe's Avatar
they don't make dexon2 anymore but dexon3 is backward compat with dexon2 so it's ok either way
Old 06-19-2008, 07:30 PM   #9 (permalink)
elahi's Avatar
Thumbs up I am safe..
Thanks! The ATF and PSF are the same for my car. So I am safe..
Regards,
