Does not like to start at the morning! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2008, 11:36 PM   #1 (permalink)
elahi's Avatar
View elahi's Photo Gallery
2nd Generation Does not like to start at the morning!
The battery is new and charged. My car does not like to start at the morning. It makes normal sound, but it takes at least 2-3 times tries. Could you advice what could be the problem?
Regards,
My car: Camry 1989 V6 Auto
elahi is offline   Reply With Quote
Old 06-18-2008, 01:10 AM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
There is a cold start injector on your intake plenum, and it is actuated by a cold start timing switch on the inlet for the coolant intake to the block.
If either of these components malfunction, the car will take extra tries to start.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 06-18-2008, 12:49 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Exactly. My cold-start injector time switch broke and had these same symptoms. It is the brown sensor on the coolant outlet neck of the motor (where the upper radiator hose meets the engine). On my car, it was right on the front and easy to replace. Luckily I had an extra one from an old motor, they are kinda expensive. If you can, grab one or two from a junkyard to save money.
-Charlie
Old 06-18-2008, 02:23 PM   #4 (permalink)
Gameroom cash: $302555
I have to agree that the most likely suspect is the cold start time switch. You can check it on a cold engine with a digital volt/ohmeter and the specs from any manual. You will be checking it's resistance. Close to spec isn't good enough; it must be within spec. Like someone mentioned, it's kind of an expensive part at the dealer; somewhere around $100. If it checks out out of range and you can find one or two at a salvage yard, that would be a posssible way to go to save some money.
Mike
