Parking brake adjustment question
I've adjusted drum brakes before, but I think the last time I worked on my rear brakes on my '88 I just put in new shoes and I think they were a little two tight, and then drums were thin I ended up warping the drums.
So this time I put on new drums and shoes. I adjusted them like the haynes repair manual said. With the star wheels turned in all the way I made numerous forward and reverse stops. But the brakes didn't seem to auto adjust. Then I noticed when I pulled the parking brake handle I heard a click. Every time I pulled the parking brake the ratchet arms where turning the star wheels a little bit. So I keep doing this about 30 times until I didn't hear clicking. The parking break set will less clicks and the brake pedal was firmer. But not like it used to be.
I haven't had the wheels off to check the drag. But what I'm wondering is how do I know what is enough drag? I searched this topic and came across this. Someone said that the drum should turn three times after being spun.
So What is the proper way? I don't what to warp my new drums.
Thanks.
