Damsel in Distress - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2008, 09:55 PM   #1 (permalink)
View kittyklise's Photo Gallery
Gen1 Damsel in Distress
I bought a new thermostat, but cannot figure out where to install it. Have a 1986 Camry 4 cyl. Thought it would be off top hose, but would have to remove distributor to install. Help!!!
kittyklise is offline   Reply With Quote
Old 06-21-2008, 11:09 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Follow the lower radiator hose to the engine. It is there, just outboard of oil filter. I believe that there is a gasket for the housing and another for the thermostat.
Kep
Old 06-22-2008, 01:31 AM   #3 (permalink)
View aych's Photo Gallery
keep a couple bottles of coolant handy else you'd be left with a puddle and a non functioning car and you'll hafta go shopping by bus!
aych is offline   Reply With Quote
Old 06-22-2008, 01:37 PM   #4 (permalink)
Gameroom cash: $302555
Do what Kep said. You will see 2 10MM hex nuts on the studs. I believe there is only one gasket (actually an o-ring). I would make sure to also replace the o-ring. It's cheap enough insurance to replace it each time the housing is removed.
Mike
