90' Camry engine stalling out after oil seal/ timing belt replacement
Recently my 1990 Camry ( 3sfe engine) starting leaking oil, and not surprisingly it was traced back to the camshaft seal. We replaced all the seals, water pump and put a new timing belt on and have ensured that the timing is correct.
Before reassembling the car we figured we’d test out the engine and only put back everything the car needs to run except the alternator belt and the crankshaft pulley. We managed to get it to turn over but after about six seconds the car just stalls out. Upon trying again, the car will crank and get very close to starting but will not turn over. If we wait a few hours or so, the car will do the same thing. We’ve tested the spark and it’s very strong, tested the fuel output, checked all the wires, ensured a proper ground on the igniter, and checked for any air obstructions. Are we missing something?
I’m at my wits end here because the car ran fine beforehand. I’d appreciate any help possible.
