clutch fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2008, 01:57 PM   #1 (permalink)
Camgod
Carlman(90 CS)'s Avatar
View Carlman(90 CS)'s Photo Gallery
clutch fluid
hey guys,
whats happening round these parts haven't been here much.
my question for today is where is the clutch fluid located?
as i drove home it became progressively harder to shift down gears and by the end of it it wants to stall if im stationary and i gear with clutch pressed in.
thanks guys
Long Live 2nd Gen!!
Carlman(90 CS) is offline   Reply With Quote
Old 06-29-2008, 04:10 PM   #2 (permalink)
View drugal's Photo Gallery
In the engine bay, driver's side at the firewall.
Sounds like you've got a bad master or slave cylinder for your clutch. What's probably happening is when you press the pedal, you're pushing leaking fluid out, and sucking air back in when you release the pedal.
Check both cylinders for any signs of leaking fluid. To check the master cylinder, you have to look up from under the dash with a flashlight.
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
Old 06-30-2008, 03:29 PM   #3 (permalink)
Gameroom cash: $302555
^ Exactly wht he said. To check for a leaking master cylinder you may have to pull back the carpet underneath the clutch and brake pedals. Most often, if you have a leaky clutch master cylinder, the fluid winds up underneath the carpet in that area.
Also, if the master cylinder resevoir is empty, adding fluid (use DOT 3 brake fluid) may allow you to get the car from point A to point B, if you can't fix this yourself.
Mike
Old 07-01-2008, 03:48 AM   #4 (permalink)
Camgod
hey guys,
my car is in for repair as i have cracked and bent the clutch fork!
anyway get it back in 4 days
thanks ageain
Long Live 2nd Gen!!
