I lost 5th gear and Reverse -- any ideas on how to fix? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2008, 10:06 PM   #1 (permalink)
View Dave88LX's Photo Gallery
My shitbox pops out of 5th gear, so I have to hold it in when I drive. Well, after a bad day, I took a little anger out on the shifter when it popped out and slapped it back into 5th. It must have overshot something, because it was free-revving with the shifter in the 5th gear position, and was stuck. I had to pull over and wrestle it out.
1/2/3/4 work fine, but 5th and Reverse now are "empty". I have my wife move the shifter around, so I see how the shift pattern works where the cables come into the transmission, or that little module thing there. When the stick is pushed far right, the "boot" gets pushed in, and moving the stick between 5th and Reverse does move the other cable. I'm guessing it's something inside that box.
Any ideas?
Dave88LX is offline   Reply With Quote
Old 07-01-2008, 03:47 AM   #2 (permalink)
View drugal's Photo Gallery
I bought a Gen2 transaxle with this exact problem once. I opened it, and found the bolt connecting the #3 shift fork to the #3 shift fork shaft had come out. It was just sitting there in the transaxle, so I screwed it back in and it worked fine.
You can get to this bolt by removing the cap on the side of the tranny. I had the tranny out of the car at the time, so I'm not sure if there's enough room to do this with it still in the car.
Yours may have broken, fallen out, or the problem could be something else in there. The Haynes manual has some good diagrams of the transaxle.
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
Old 07-02-2008, 09:40 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the cap is right be hind the drivers wheel and splash shield
Old 08-14-2008, 10:04 PM   #4 (permalink)
View Rawtunes's Photo Gallery
Im having the same problem but when i try to shift to 5th it acts as if it was in 3rd and the same goes for reverse but acts as in 4th.
has anyone fixed his problem yet?
Rawtunes is offline   Reply With Quote
Old 08-15-2008, 09:54 AM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
shifter cable bushings at the tranny end are bad
Old 08-15-2008, 01:33 PM   #6 (permalink)
Would you say is it easy to fix it myself or does it require a mechanic?
Old 08-15-2008, 08:34 PM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
nope but it does require some rubber arms to get to em though
Old 10-26-2008, 10:30 AM   #8 (permalink)
Excellent. I will have to try to get at it then and fix this damn beater!!!
