FYI Digital Cluster - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2008, 04:59 PM   #1 (permalink)
1986rollaae82 R.I.P.
chuck_arvin's Avatar
View chuck_arvin's Photo Gallery
Gen1 FYI Digital Cluster
This is for you gen1 guys looking for a digital cluster. I found one on eBay and just thought someone would like this. http://cgi.ebay.com/ebaymotors/86-85...2em118Q2el1247
2007 Camry SE 2AZ-FE 5-Speed Manual
1990 Camry Base 3S-FE 5-Speed Manual
1989 Camry DX 3S-FE Auto (R.I.P.)
1986 Corolla 4A-LC 5-Speed AE82 (R.I.P.)
chuck_arvin is offline   Reply With Quote
Old 07-07-2008, 09:13 PM   #2 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
View TVISMR2's Photo Gallery
I've seen them pop up on ebay from time to time. If someone were to do a conversion to the digi gauges they would need a bit more than just the cluster though unfortunately...
cluster wire harness
dimmer switch and harness
fuel level sending unit (from under rear seat)
I actually have an extra complete digi swap sitting here
1992 TOYOTA MR2 - 180k miles * 2003 TOYOTA MR2 Spyder - 87k miles * 2006 SUZUKI SV650s
2002 TOYOTA Highlander 4wd Limited V6 - 25k miles * 1985 TOYOTA CAMRY DX - 130k miles *
1987 HONDA Elite 250
Hers ~ 1988 TOYOTA MR2 Supercharged - 87k miles * 1999 TOYOTA TACOMA - 125k miles
TVISMR2 is offline   Reply With Quote
Old 07-12-2008, 01:35 AM   #3 (permalink)
View Kingdom934's Photo Gallery
Your gonna need the Fuel sender from a car with a Digital Cluster (I think one from Gen2 car w/ digital cluster might work too, but not sure).
Also, your going to need to slice and connect each wire (NOT plug AND PLAY) behind the cluster.
What I'm looking for is a Gen1 '85/'86 LE Analog cluster...
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 07-12-2008, 11:08 PM   #4 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
^ That's easy. I could get like 10+ of 'em in a day. 1G's all over the place at the JY's here.
Old 07-16-2008, 12:14 AM   #5 (permalink)
Lucky you.
There was a RUNNING Gen1 that came in a junk yard one day when I was at the one here. I decided to come in the next day to parts strip it...it was on a flatbed to be taken to recyling I believe. It only had 95K on the obo...
Sucks though, it was an DLE however.
I hardly see anything older then Gen2 camries the one junker I go to. Gen2's are all over the place with a few Gen3 and one or two Gen4.
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 07-29-2008, 06:56 PM   #6 (permalink)
View Dudeguesswhat's Photo Gallery
Gen1
Sooo how many digital clusters are there for Gen 1s?
I just found this one: http://cgi.ebay.com/ebaymotors/83-86...3286.m20.l1116
It's a bit different than the one I have, which is the same as the one linked in the original post of this thread.
Just curious if anybody knew
Dudeguesswhat is offline   Reply With Quote
Old 07-29-2008, 10:00 PM   #7 (permalink)
I just found this one: http://cgi.ebay.com/ebaymotors/83-86-1986-TOYOTA-CAMRY-INSTRUMENT-GAUGE-CLUSTER_W0QQitemZ280242017717QQcmdZViewItem?_trksi d=p3286.m20.l1116
That cluster is a mistake. I've seen that a while when I keep searching eBay for the analog '85~'86 LE cluster w/ tach.
That cluster there is for/from the 2nd Generation Toyota Cressida MX63 ('81~'84)
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 07-29-2008, 11:56 PM   #8 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
Yuck. I like the Camry one better.
Old 07-30-2008, 12:20 PM   #9 (permalink)
Yea, I don't care too much for it.
I'd say though, between the Gen3 Cressida and the Gen2 Camry, I like the Crressida digital dash, but the Gen2 has a more modern'ish digital one as it is a bit more roundish design
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
