Trans model? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2008, 01:08 AM   #1 (permalink)
View Lee250's Photo Gallery
Gen1 Trans model?
I have an 86 camry with a 2.0 fuel injected gas motor and a 4 speed automatic trans. Anybody know the model or the number of my trans or how can I find out?
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 07-08-2008, 12:17 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
It is either the A140L or A140E. If you have the "ECT PWR" button or similar, it is the electronically controlled A140E, otherwise you have the A140L.
-Charlie
Old 07-08-2008, 01:00 PM   #3 (permalink)
View toyomoho's Photo Gallery
Check side of drivers door for a sticker. If there typically should state model type somewhere on sticker.
Old 07-08-2008, 07:03 PM   #4 (permalink)
日産自動車パワー!
JMSports's Avatar
View JMSports's Photo Gallery
-Charlie
Yea what does the ECT PWR button do. I never got a manual with my car.
Also does anyone know how i can get a owners manual for my 90 Camry?
Like does Toyota have them?
マイクジョンソン.___________________私は日産マキシマ自身ビッチ!
JMSports is offline   Reply With Quote
Old 07-08-2008, 09:26 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the button changes the shift pattern and firmness and try ebay for a manual
Old 07-08-2008, 09:35 PM   #6 (permalink)
6 TOYOTA's in stock
TVISMR2's Avatar
View TVISMR2's Photo Gallery
PWR mode FTW
1992 TOYOTA MR2 - 180k miles * 2003 TOYOTA MR2 Spyder - 87k miles * 2006 SUZUKI SV650s
2002 TOYOTA Highlander 4wd Limited V6 - 25k miles * 1985 TOYOTA CAMRY DX - 130k miles *
1987 HONDA Elite 250
Hers ~ 1988 TOYOTA MR2 Supercharged - 87k miles * 1999 TOYOTA TACOMA - 125k miles
TVISMR2 is offline   Reply With Quote
Old 07-09-2008, 07:00 AM   #7 (permalink)
日産自動車パワー!
JMSports's Avatar
Lawl.
I also got a "Release for emergency exit" lever right next to the parking brake, and a large rectangular red light behind the EXT PWR button that says press here to release or something.
Old 07-09-2008, 12:53 PM   #8 (permalink)
white90dx's Avatar
Originally Posted by JMSports View Post
Lawl.
As do all the US market gen2 Camrys... It releases the tension on the shoulder belts in case of an accident (ie stuck upside down and seatbelt is holding you up).
-Charlie
Old 07-09-2008, 01:04 PM   #9 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
cute icon chuck
Old 07-10-2008, 08:37 PM   #10 (permalink)
View vinash's Photo Gallery
How do you identify the trans if it is at a wreckers and taken out of the car?
vinash is offline   Reply With Quote
Old 07-11-2008, 03:30 PM   #11 (permalink)
white90dx's Avatar
Originally Posted by fredk View Post
cute icon chuck
That's from an actual picture of my Alltrac Camry. Hehehe...
Old 07-12-2008, 01:16 AM   #12 (permalink)
View Kingdom934's Photo Gallery
There was a video that explain the NORM and PWR settings. I think a guy with a GEN3 did it.
For example, if your running in NORM mode and you floor it at 40MPH, it would normally downshift to only second (if you were in third or forth). If you have it in PWR mode, it would downshift to first and go up to redline to around 45MPH and shift into second. Basically, if you keep it in PWR mode, it would downshift at a higher rev and keep it in a gear until red line.
Here's the explaination
http://www.toyotanation.com/forum/sh...63#post2074663
Originally Posted by ASG14 View Post
Ok, I am sSick and tired of people responding to threads with misleading and incorrect info. SO READ!!!! So next time a New Member askes a question on it, simply refer them here, so
they get the correct info!
O/D Dont’s:
1: O/D off during acceleration is retarded, end of story.
2: O/D off during cruising, or just normal driving, IS STUPID, period.
O/D Do’s:
1: O/D off should be used with the anticipation of passing at highway speed. It gives you that split second more power (Not needing to downshift) for the pass.
2: O/D off should be used if going up a steep hill at highway speeds where you start to loose speed.
ECT Don’t’s:
1: Normal Acceleration with PWR on. If your accelerating normal, why in hell would you have PWR on? Dumb.
2: Normal Driving. Read above.
3: WOT with PWR. See video’s below. NO DIFFERENCE!!!!!!!
ECT Do’s:
1: Heavy Acceleration but not at WOT. PWR will have it shift at a higher RPM for a smoother and faster acceleration.
2: Heavy traffic. I.E., New York City highways. PWR causes the tranny to downshift to a lower gear, at a higher RPM, for a MUCH faster acceleration. See video's below.
ECT PWR and O/D OFF
1: Ok, just see video below and look at RPM's and maybe you'll see why your MPG is so bad.
REV Limiter Discussed:
1Q: Will hitting the Rev limiter cause my engine to explode?
1A: No, it will not. The Rev Limiter (6750 RPM’s on the 1MZ Gen 3) is there to PREVENT damage. If it would cause damage, the limiter would be set lower.
2Q: What does the Rev Limiter sound like?
2A: See video below.
3Q: Since hitting the Rev Limiter is not going to kill the engine, can I do it all the time to look cool?
3A: Yeah, but enjoy looking like a Tool when you end up doing it so many times, you DO kill the engine. Redline is there for a reason ya know! It’s normally ok once in a while* but not all the time.
* Disclaimer, If you blow the engine, TN nor any members are responsible for your stupidity. In no way is it good to hit the Rev Limiter, or recommended in any way. Under most circumstances, it does not hurt, but still should not be done.
You can go to the link above for the video explanation
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
