A/C Diagnosis
I have an 89 Toyota Camry which the A/C doesn't work. In last trip to the shop, pressure was checked, found a leak, repaired, checked compressor (ok), and added freon. When A/C switch is pushed compressor kicks on for 5 seconds and goes off and begins blinking. Mechanic chased wiring back to A/C amplifier. Any ideas about diagnosis. Is replacing the A/C amplifier as help in diagnosis and does that eliminate anything. Used part is about $40 and if that helps eliminate something, we are willing to try. But I don't want to waste lots of money trying to get a diagnosis. Any help or suggestions appreciated. Thanks, Lenis
