the engine sounds fine as it starts but as soon as it fires the noise begins.
noise is present in all shifter positions. PRND21
one thing I just thought of, the car was making some rattling noise before with the engine running, when shifted from P to Reverse it would really amplify the noise/problem
Originally Posted by Doctor J
Let's put symptoms in order:
Rattle-grinding noise present while engine rotating with starter , with engine running in park or neutral , car has no gears,
The problem most likely the transmission input shaft or turbine wheel inside the torque converter.
in any case tranny must to come out for inspection
