I'm officially exhausted and I need a mechanic in PA!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2008, 12:32 PM   #1 (permalink)
View don-vee's Photo Gallery
That's it, I've had it. I have been working on swapping the motor into my 89 Camry for 2 weeks now. THOUGHT I had the torque converter lined up right. I dropped the motor in, lined it up, bolted up the bellhousing bolts, then noticed the flywheel pressed against the lower part of the bellhousing, which made me think the torque converter slipped out of its spot again. Unfortunately, the center nub on the converter is now completely stuck inside the center hole on the flywheel, and I have been prying and hammering at it to no avail. Can't put the motor in, can't pull it out. I'm stuck, in all sense of the word.
If this were a krusty old V8 hot rod, or an aircooled VW, I could have had a dozen engine swaps completed by now.
Soooo, anyone here in Northeastern PA who's a good enough mechanic to help me out on this? I took off enough time from work, I need to get back to my life and leave this car in the hands of someone who knows what they're doing better than me. I'm serious. PM me please.
don-vee is offline   Reply With Quote
Old 07-18-2008, 09:36 AM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
sounds like there was a pilot bushing in the crank from a 5 speed, pull the motor with the trans bolted to it, snatch the trans straight off it and pry the converter off the motor with prybars, then put a new converter seal in the trans and put it back together
Old 07-22-2008, 04:49 AM   #3 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
Wink
Hi Don-Vee,
I'm sorry about your frustration.
I would consider Fred's suggestion first if possible.
I'm located in Easton but I think that's some distance from Wilkes-Barre.
If you really want a mechanic, I can refer you to one; but he would be located in Easton.
Just to understand the whole picture, what kind of motor swap are you working on?
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
