Timing belt and crank pulley - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2008, 08:01 PM   #1 (permalink)
View PtypE's Photo Gallery
I have an 86 camry dlx
I decided to replace the water pump myself, largest mechanical job i have done, but i am not totally inexperienced. But i did completely fail at one thing. It was not the correct placement of the timing belt, i got it on keeping things lined up, but i forgot to tighten the tension pulley down. See attached pics.
Now that i have a new timing belt and have the car mostly taken apart, im missing one tool i had the first time. An air impact gun, I used it to take off and replace the bolt on the crank pulley. I had my GF get in the car and put it in first and stand on the break as i yanked and pulled on the bolt with a socket wrench to no avail, is there an easier way to get more grip then taking off the starter and locking the flywheel with a screwdriver? (suggested by a friend)
PtypE is offline   Reply With Quote
Old 07-17-2008, 11:18 PM   #2 (permalink)
got pulley off, and found new timing belt is the wrong type...
After close inspection the old timing belt will do, wear is superficial, valve timing is good but ignition is off, unfortunately the main engineer must have been out the day the design for the distributor cap was drawn up...
The cap is permanently connected to the wires, I would have just swaped them around till I got the sequence correct. So i went to take the cap off to alter the sequence with the needle, but the third screw for the cap is almost covered by the heater core hose... making it nearly impossible to get, unless i remove the hose...
Lost daylight for today, will resume working tomorrow morning
This has been an exercise in frustration!!!
Old 07-17-2008, 11:20 PM   #3 (permalink)
Oh, one last thing, I have the small 0 shaped hole in the cam pulley and the notch on the crank pointing straight up
If anyone can confirm, that this is the way to get the timing lined up...
Old 07-18-2008, 12:32 AM   #4 (permalink)
come on, someone has to have changed a timing belt on this model
Old 07-18-2008, 01:25 AM   #5 (permalink)
ok, search function, very helpful, i know, got the marks for timing, both cam and crank, wont mess with the other stuff
now why did kragens give me the wrong timing belt?
Old 07-18-2008, 09:13 AM   #6 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
First of all, your engine looks to me like 87 3S-FE so the car is 87 model; [it probably was made in Nov 86 but this is NOT model year); so the guys in Kragen sold you the belt for single cam 2SFE pre-87 engine.For future reference reafd my thread about the timing belt.
Doctor J is offline   Reply With Quote
Old 07-18-2008, 09:16 AM   #7 (permalink)
Doctor J's Avatar
If you took more pictures in the process, could you post these?
Old 07-18-2008, 10:30 AM   #8 (permalink)
View toyomoho's Photo Gallery
The engine model may stamped on the back of the block above where the trans housing bolts up.
For future ease of frustration it is always best to compare any new part with the old before installing.
Old 07-18-2008, 01:34 PM   #9 (permalink)
great, so if its a 87 model does that mean the thermostat and water pump are not the right kind either?
I will go and get more pics now
I did find all the info on the timing belt alignment and know how to properly check it now
also if i remember correctly if its an 3S-FE and the timing is wrong it will not bend the valves?
Old 07-18-2008, 03:42 PM   #10 (permalink)
i did it, i got the correct timing belt, and timed it perfect, runs great, even sounds smother then before
Old 07-18-2008, 03:46 PM   #11 (permalink)
