A/c problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2008, 09:37 PM   #1 (permalink)
Gen 2 Camry
WannaBButch's Avatar
View WannaBButch's Photo Gallery
2nd Generation A/c problem
So on my way home from work the other day on the highway, my water pump bearing went out and the car overheated and made horrible noises blah blah blah. So I yanked it off the highway and shut it off. I got it towed home and got it all taken apart. Replaced the water pump, timing belt, all other belts, oil, coolant, etc. Now my a/c doesn't work. The compressor kicks on but it blows out HOT air. It's not even outside temperature. It's friggin hot. Does anyone have any clue?
WannaBButch is offline   Reply With Quote
Old 07-24-2008, 09:45 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
hook your heater water control valve back up, its on the heater hose by the firewall
Old 07-24-2008, 09:51 PM   #3 (permalink)
Gen 2 Camry
2nd Generation
I didn't take it off but I will check that in the am. Anything else I should check as well? Dad thinks the heater control valve is stuck open or something.
Old 07-24-2008, 10:28 PM   #4 (permalink)
Gen 2 Camry
2nd Generation
Okay so the lever on that thing was stuck. I moved it manually and the a/c works now. Thanks for the direction!
