Headlight Integration (relay) Conversion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2008, 04:36 PM   #1 (permalink)
View davearmmn's Photo Gallery
Has anyone added the auto headlights shut-off feature to a Camry that came without it? I have the integration box but I can not find a wiring harness and plug. It looks like it could be spliced in if I was a contortionist.
davearmmn is offline   Reply With Quote
Old 02-15-2009, 01:22 AM   #2 (permalink)
View heat_z0ne's Photo Gallery
hi bro
I think its hard to put auto headlights shut-off feature, at list for me
Easy east Way is to Put Buzzer Between Headlight & Driver side door sensor
I m still looking for this Solution because i m not expert, if some one has detail let us know
Thanks
heat_z0ne is offline   Reply With Quote
Old 02-15-2009, 02:38 AM   #3 (permalink)
View nuron's Photo Gallery
The integration relay is located behind the driver's kick panel fuse box. I might try to see how to remove the fuse box tomorrow.
nuron is offline   Reply With Quote
Old 02-20-2009, 05:23 AM   #4 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
Headlight Buzzer / Bell
http://shop.ebay.com/items/headlight..._dmd=1&_sop=12
Answer
The headlight on buzzer must be wired to the door switch as well as the lighting system. It is not necassary to wire it to the headlights as the park light will be illumintaed at the same time and wiring it to the headlight is more involve as you have to wire it to the low and high beam The door switches are linked to the interior light and provide an earth when the door is opened, Look on your fuse cover and locate the park lamp fuse. Using a connector take a lead from the fused side of the supply (remove the fuse while the lights are on and one side of the contacts will lose power)You need to connect to that one. Run this to where you are going to secure or locate the buzzer. Connect this to one side of the buzzer. Depending on what type you are using it may be critical to get the positive and negative connection correct. So place the supply from the fuse box to the positive side. You could leave the fuse out while doing the job in case you leave the lights on and create a short circuit while working with the wires. Trace the wire from the door switch and connect a second wire to this and run it to the other connection on the buzzer. Refit the fuse and test the circuit.
malayan is offline   Reply With Quote
