1986 camry tranny question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2008, 09:34 AM   #1 (permalink)
View steamplant's Photo Gallery
Hi folks,
I'm new to toyot, great site here. I recently purchased a 1986 camry with 74,000 original miles on it. I paid a little more than I wanted to, $650 but I got it from a recently widowed nice lady.
Anyway the car needs some work, I noticed that when driving at highway speeds around 50 mph or so the transmission "overdrive off" light flashes on and off periodically.
Is this normal for a camry? or does anyone have any ideas on this?
This car also leaks water into the trunk area, looks like small rust at rear windshield moulding, is this common? Any suggestions on repair?
thanks
steamplant is offline   Reply With Quote
Old 07-26-2008, 10:32 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
For transmission, short Tt terminal to the E1 terminal of in the diagnostic box, and turn the ignition on, but don't start the engine.
Count number of blinks from o/d off light,[four -pause- two- long pause , for example means code 42] then unshortwen the terminals and turn ignition off
Post the number you get here
Doctor J is offline   Reply With Quote
Old 07-26-2008, 03:57 PM   #3 (permalink)
View Kingdom934's Photo Gallery
Rust is common around the top part of the rear window top right and top left (When looking at the car from the rear) areas. Mines has rust spots there. Also, check the roof 'gutters' as they tend to rust out up there and eat the roof. THe trunk also rusts out (check around the sides where the weather strip is, mines leaks there. Also, take off the tail lights and check the body underneeth the tailights. Two gen1's I've had all had rust there also.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 07-31-2008, 08:34 AM   #4 (permalink)
No terminal Tt
I don't see a terminal Tt in my diagnostic box, the only ones that begin with T are "T" and "Tem" .
This car runs pretty good except when going into second gear it really bogs down, takes a long time to gain speed. Almost like it is going from 1st directly to 3rd gear. I have been manually putting it in second with the shifter to gain speed then putting it back in the "D" position.
Any ideas?
Old 07-31-2008, 08:45 AM   #5 (permalink)
Doctor J's Avatar
It's not Tem it's TCM. Use (TCM) and E1 terminals to get the Diagnostic Codes.
Old 07-31-2008, 03:34 PM   #6 (permalink)
I only have "T" and "Tem"
Doc,
I checked again, the only terminals begining with "T" are the "T" terminal and another one "Tem" I checked it twice. I have a total of 11 terminals identified on the box lid or an I missing something?
thanks again, this car is awesome 28 mpg city driving
Old 07-31-2008, 04:29 PM   #7 (permalink)
Doctor J's Avatar
Is TEM terminal located at 2 by there terminal cluster [closer to the windshield of the car, farther from the radiator?]
Do you have power/normal push button near the hand brake?
Old 07-31-2008, 06:05 PM   #8 (permalink)
yes ,2nd cluster
TEM is located in the second cluster nearest the windshield, it is the 2nd terminal on the left hand (drivers) side of the box. Yes this car does have the normal/pwr switch by the handbrake. I tried driving with the pwr switch enabled it didn't seem to make a difference, thanks
Old 07-31-2008, 08:59 PM   #9 (permalink)
Doctor J's Avatar
On my car [87 Camry] the transmission test terminal is labeld Ect and located next to Tem
It is located in the upper right corner of the 3 by 2 cluster, closest to the driver side mirror.
This terminal must be grounded to E1 with jumper.
