Originally Posted by Kep
I am pretty sure that the blend doors are controlled by the AC control and the location control. The coolant flow (whether to heat, ac or nothing at all) is controlled by a valve operated by a wire connected to the temperature control. Look just behind the firewall in the engine compartment where the heater hoses pass into the passenger compartment. On one of them you will probably see a plastic looking (mine is round) valve. If that isn't closing completely you will be getting some coolant being allowed into the heater exchange in the cabin and, therefore, heat.
I'm not sure how a mal functioning blend door would affect the situation. Also, if you have outside air coming in it passes over the heater exchange and pass more heat into the cabin until you are able to shut off the coolant so it may be better to shut this off until you fix the other problem.
Kep
Heh i have the same problem. The AC worked before i got the car, and i went to use the AC for the first time 2 weeks after i got the car, and no matter what setting the heat is in AC or not, hot air just comes blarring out and its annoying the piss outta me cause it was cold once.
Either the freon or w/e is escaping through a slow leak? or i have the problem listed above, maybe ill check it 2m.
