You can do a similar thing with the A540E/H using a multimeter and the diagnostics port. I think it will also work with the A140E... There is a pin on the diagnostics port that outputs a voltage relative to the gear and lockup condition - it is actually pretty fun to watch. The procedure is listed in the factory service manual. It won't tell you want is actually getting to the transmission, but it tells you what is supposed to be happening.
-Charlie
