Hi, I'm trying to get this 88 LE brake light issue fixed before a trip. We can't get the power to the brake lights.
I'm much too tall and HUGE to contort myself under the dash. I've volunteered my kids for much of this work in an effort to teach them as well. Their info is pretty reliable but I follow up and dbl check where I can. Here's what we got figured so far.
There's an odd jumper wire just before the Left tail light housing. (see pic)
Wires in the black tape/wire harness behind the left trunk hood hinge are very flat, there appears to be a burn mark in the tape. We still need to open it all up and check for bare wire.
Test light shows power to blinker (it flashes very rapidly w/o tail light pkg attached but normal speed when hooked up), power to tail light but not to brake light.
20 amp fuses in Left kick panel are all good but I want to double check all the fuses are in the right place still. Never know if a wrong fuse is in the wrong place.
They say visual of brake switch is ok but impossible to replace. One thread mentioned it took them a few hours to replace it. Can this be tested with a light or multi-meter?
I don't recall the lights working on the rear dash either and I'm not sure the back up lights work which would give suspicion to the smashed wires at the hinge.
Side question:
Does adding Lucas gas treatment clog stuff up? It seems the pick-up-and-go just got up and went until we get to 2500 RPM. I found a paper blue shop towel shredded in pieces inside the air cleaner box. I cleaned it out, pounded the dust a bit, and no change. Going to do a tune up anyway.
It's 1:30 am. Hopefully the pic will show up ok.
Thanks all!
