Camry wagon rear end - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-06-2008, 11:00 AM   #1 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
As I am not very good suspension expert I need to know if anyone was able to find the answer why some Toyota station wagons are appeared to have "elevated " rear ends. I have seen it on some older Cressida s/w and most 4 cylinder Camry s/w[including mine].
At first I thougt about it as a normal feature for extra stiff rear springs, but I noticed that the 6 cylinder Camry wagons as well as Corolla wagons do not exibit this "feature".
Please share your thoughts and suggestions.
Doctor J is offline   Reply With Quote
Old 08-06-2008, 01:09 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
I remember something about a factory ride height section in the BGB? Maybe that would shed a little light on it?
I don't see why they would be a whole lot different between different models. Maybe the struts on your wagon have been replaced by sedan struts or something? Maybe the spring seat is different on the wagons compared to the sedans (more spring preload)?
-Charlie
edit: Check the Service Specification section of the manual. The wagon is supposed to sit about 1" higher in the rear than the sedan with the V6 .24" lower than the 4-cylinder. (found on page A-33 of the service spec section)
Old 08-06-2008, 01:36 PM   #3 (permalink)
Doctor J's Avatar
Thanks, Charlie,
I was aware of almost 1 inch difference between 88 sedan and wagon.[both 4 cylinders]
The struts are OEM, and they are not in the good condition [21 y.o.].
Kragen is selling struts that is the same p/n for sedan and wagon.
Recently, I saw 4 cyl. wagon which had no "elevated rear end" feature so that is why I asked my question.
If next year we would not retire the car because of the smog, I would plan to change rear struts; at the same time I would like to do something about the rear end.
Old 08-06-2008, 10:18 PM   #4 (permalink)
ozzi
View oz43's Photo Gallery
I have the same issue with my 87 wagon. I believe it is the wimpy front springs. I replaced them a few years ago with OEM and that did nothing. I can still roll over a dime and the front bottoms out!
Fort Worth has a couple custom spring sources. I have be told custom springs would be costly. I just haven't ask yet.
ozzi
oz43 is offline   Reply With Quote
Old 08-06-2008, 11:55 PM   #5 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Doctor J, you said that Kragen shows the same p/n for sedan and wagon...do you mean for the front struts? Because the rear struts are definitely different. I put wagon struts on the rear of my V6 sedan to handle all the extra weight of my subs and my tools...and fully-loaded, the rear deck still sat almost one inch higher than with the original sedan struts. Perhaps Kragen was looking-up the front strut assembly?!
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 08-07-2008, 08:58 AM   #6 (permalink)
Doctor J's Avatar
No, I believe there were rear struts, but I will double check
Old 08-07-2008, 09:03 AM   #7 (permalink)
Doctor J's Avatar
Just berief update; the Autozone is listing different part numbers for sedan and wagon!
Old 08-07-2008, 07:25 PM   #8 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
Hmm ok so if I understand this correctly, if you put wagon rear springs on a sedan the back will sit higher ?! Like the wagon ? That would be useful for people that carry s very heavy loads more often
Seems like the wagons that do not sit higher in the back has had there springs Replaced.
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
