1st & 2nd Generation (1983–1986 & 1987-1991)Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
ive used a search, but i cant find anything specific to my 85....
im hooking up an aftermarket deck in my 85 camry le....can anyone tell me whos done this what color the wires from the stock harness are for constant / switched (accessory)..its all hooked up...and it has power...but it resets whenever i remove the key....so obvoiusly im not getting it right....
is there a diagram somewhere of the pins?
Thanks
Paul
91 ext cab,3.0 5 speed, headers, k&n intake, crane coil, borla exhaust, 4" suspension, 3" inch body, 35" Kuhmos, Detroit EZ lockers front and rear, champion 9500 winch, bushwacker flares..It gets me through the winter
1985 Toyota Camry Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Black/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
This should be in the Audio, Video & Security forum first of all..
and second of all a simple google search would have yielded you these results.
Woa thats pretty damn detailed , do you have a link where you got that from ?
well...thanks for the info...but on my car...im not sure whats up...but thats not the colour of my wires in my factory deck.....
its all working now...but i ended up finding a map of both plugs pin arrangement.....traced the wires back to that and went from there....
i think the only wire that was the same colour was the ground....
i have no blue yellow wire and no grey wire......the 12 v one was white with i think a black stripe...
if anyone wants the rest i can give a full explanation
Cheers
Paul
well, first off, the small plug is white plastic...
i still have the factory connectors i removed....ill snap a cell pic of them tomorrow and post it...
but i went to installdr.com (sp?) and got the pin arrangement..its the only way it got figured out
Itll be interesting to see when i add a sub and amp to the my truck (see sig) on the weekend...see if its the same
ok, below is a schematic i altered and added my wiring...along with a picture of my factory plug......
and...in case anyone thingks mine was altered..the plugs are stock, no signs of alteration, and everything worked with the stock deck before it was replaced....
hope this helps someone avoid the issues i had
Cheers
Paul
